For those of you getting a console flip setup here is an overview of what is involved:
First off you'll need to drill and mount the hinge. In this case the seat box has the bump out so the console goes flush with the back, you might be drilling on the base of the console if you want it to fly off the back edge.
Now you need to get this thing bolted to the base so that the pin engages the latch:
Latch it in place and bring the console up to meet it and make a mark where the arm hits the box, that is where you will need a slot.
Now just make a rough mark for where each side sits.
So you now have the center and the extents marked out where the arm needs to go through the base.
You want the slot all the way to where my fingers rest in this pic, otherwise it might interfere with latch function.
Starter hole:
Enlarge.
Make sure it's big enough to clear the arm.
Then cut your slot. I used a cutoff wheel, a jig saw would work just as well.
After the slot is in place you should be able to set the bracket and latch in place on the pin and mark and drill for the mount holes.
I found the floor of the console to be too weak to give a nice positive feel to the latch so I made these reinforcing plates for inside the box.
They will make a sandwich plate when bolted together with the lower bracket and the edge bolts will use the strong vertical wall to cancel any deflection.
The holes are slotted to allow for a ton of misalignment. I made these plates off the measurements of this old console a customer sent me, I sure hope the newer ones measure the same.
Then there are two holes that need to be drilled on each side, if you do this with the bracket already in place it will be easy to determine just where they should go, about 5/8" up from the bottom.
And about 1 5/8" apart, it's not very precise.
All bolted into place.
Sturdy:
Check the video above to see the console in action, the only thing let to do is attach the end of the cable somewhere so it's easy to find and pull to actuate the flip.
