Need to make a decision fast, 35" 4:11s and 3 inch lift
35" tires will rub like a mother when wheeling but will sorta fit with an OME lift. Better bet is to get a 2" over shackle then deal with shims/alignment issues but you will still rub if you really wheel it. I did a 2" over shackle+2" body mount+cut fenders and still rubbed the s*** out of it but I was wheeling hard with 35x 13.50s.
A lot of this comes down to mall cruiser. You either go for it for real or you go for show. Bettter off with 33" that dont slam you when you flex than 35" that hit you al the time.
With the 62 you MUST go with 4:88s with 35"s. I tried it over 10K with 4:11s then tried it again over 15K wit 4:88s. No comparison.
Well I've been looking into this diff ratio thing my self and although i posted a thread asking about 4.56 i now think i'll go 4.88. The 4.88 will take the overall ratio back to what it would be with 31's and i'm running Q78's (just a tad over 35")
Seen as though you got the option i'd be going 4.88.
4.11 will pull your truck along ok just a bit slower than before and you'll keep wishing you had an inbetween gear.
as for the lift. I run 2" body and 2" spring with exteneds and they do rub occassionally but not enough to worry me. Also run 25mm offset rims.
Good luck
