Need help with a thin/long jaw puller tool
Los Angeles, CA
Anyone have a link to a puller that works for the drive clutch hub in the front extension housing of the transfer case? The FSM suggests this tool:
I tried using the same OTC 2-jaw puller that I got for the transfer gears but the arms are too thick to get into the space around the housing (you can fit it but the pull isn't straight at all.)
This one looks like it might work (either the 6" or 8" version) but the shipping time is crazy long.
Anyone have a link to one they've used, or suggestions on alternative methods?
Thanks!
I used a puller similar to the first you pictured, put together all wrong. Rather than mount the puller arms as they were meant to be, I installed them to the outside of a link. It wasn't pretty, and took some fidgeting, but it worked. It doesn't take a lot of force to get things apart in that housing.
