Need help sourcing some torque specs.... (1 Viewer)
The Sunshine State
I have a bit of a project going on with a UZ motor/h152 transmission/70 series case... Having a little trouble tracking down some torque specs. Ive tracked down all the parts just need some final specs to bolt it all up.
I'm after...
2uz Flywheel bolt torque specs
2uz Pressure plate to flywheel
2uz 2 piece bell housing
2uz Bellhousing to transmission
Ive been hunting around the web for awhile with no luck.
152 and 2uz bell housing
I'm after...
Hey Al!!
2uz Flywheel bolt torque specs: 22ft-lb each, then another 90* (opposite bolt pattern technique)
2uz Pressure plate to flywheel: 29ft-lb
2uz 2 piece bell housing: 53ft-lb
2uz Bellhousing to transmission: 27ft-lb
And where is this beauty of a powerplant going into? 45? 73? LR?
You are and will always be “the man”! The 3uz/h152/70series case is going in my fj45 🤙
