I bought another key for my 2006 LC. I bought one with the remote electronics included but, of course uncut.
I followed the steps below to program the remote but can’t get it to work!
(These instruction are different than those already posted in the FAQ section.. they should be for LCs 2003-2006)
My question: Do I need to program the chip/transponder FIRST, before being able to program the remote??
Given that the final step states that you can add multiple remotes at step 6 C, I don’t think it matters that I didn’t use the key/transponder leading up to that step… thus, I don’t think I will have successful after cutting the key and programming the transponder..
The reason I’m asking is because when I use my existing key (with remote), I get it to work! I use that key through all steps and get the car to acknowledge successful programming! When using the other key (not cut so can’t use it to enter the programming mode) at the final steps under 6), I get the feedback that the remote is not accepted (two cycles of unlock/lock of doors instead of one)
I contacted the vendor, and he said “you have to go to the dealership to program the key”..
For Toyota Land Cruiser 2003-2006
(Maybe post to FAQ IF we can figure out how to make it work..)
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition (Do NOT Turn) Pull key out.
B. Insert the key into the ignition (Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition (Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
not accepted.
