Need help: 80 series Tech Question (2 Viewers)
G-Cat
Georgia
Just back from a 1800 mile road trip. New radiator did great (thanks c-dan!)
I noticed a couple of oil patches in the driveway this morning. Further investigation reveals the following:
There is a rubber tube/hose extending from the driver-side engine compartment (inside the frame rail) with a "tension fastner) on the end that was disconected. I re-conected it to it obvious mate: this being a brass nipple on the driverside axel tube, just inside the frame rail and located on the backside of the axel tube.
So, what kind of fluid did I lose and how do I replace it? It's all over the front undercarriage on the driver's side. Anyone?
Thanks,
Garth
Sounds like the differential breather hose. I'd check the level of your diff fluid to make sure there's enough in there.
:beer:
Rookie2
Garth,
You should consider extending your front and rear diff breathers and modifying the flapper valve to eliminate a vacuum which leads to inner axle tube seal failure. (All this assumes you plan to use the 80 off-road. It it's destined to be a mall cruiser then you can forego this project.)
-B-
Also check that you don't have water in the axle. If your gear oil is gray and goopy instead of clear, you should probably get ready for a front axle job. But you could just drain and refill and see if it stays clear.
HTH,
Garth,
I'm having a BF repacking party at my house on 13-Nov. PM if you're interested in joining us.
John
