Wanted need fj40 front motor mount frame brackets
newport RI
I need the portion of the bracket that is welded/rivoted to the frame. not the isolator or the engine portion of the bracket. any of you guys that have done a 350 swap have a set lying around??
trying to fit a 87' 2f in a 64'fj45 and while I have the engine brackets and the isolators I need the fj40 frame brackets (for just the front mounts)
thakns Jason
thanks Don
I have a good set of these I carefully took off of a 66 fj40 frame. By "carefully" I mean that I drilled out each rivet with a 1/4" bit and then used a punch/drift to remove remaining rivet.
If interested, let me know. I'm in Northern California (95993). You would have to pay for shipping but the parts are free.
Mike i will take them.. and if all you wantfor them is shipping tplaease make sure you send your address as well so I can send back some stickers. i can paypal you or send a check .address is
i will pm you the address
And Don thanks i hope you read this before you start tearing throught your cruiser parts but Mike's sound like a good fit .
thanks again Jaosn
