so, from a stop, in no hurry to get anywhere, and after a 1/2 dozen tries. 2nd gear shift is about 10-15 mph, 3rd gear shift is about 22-27mph followed by overdrive around 30-40mph, almost instantly followed by lockup. if you are heavy on the gas in 2nd gear and let up, above 30MPH it will shift to 3rd then OD and lockup pretty quick. but with normal driving it seems to shift through the gears in a stepped manor, lockup hits right after OD so it almost seems like one shift, you can just see the tach step through OD and lockup.
p.s. keep in mind i am running 315's with factory gears.
