nav went black
the thing did it one more time.
took it to car toys and had them remove the dice thing to see if it fu#ks up still
well see
:mad::mad::mad::bang::bang::bang:
no dice no problem
now to find a ipod hookup that isnt a hunk of sh!t
dice=:flipoff2:_:D
I really want a newer truck with NAV, but all the issues scare me too death! I may just stick with my Garmin...
Pint, in-dash aftermarket nav is the way to go! Ipod and bluetooth and sat radio and nav all in your dash without crap all stuck to your windshield/dash.
after market /no climate crap to deal with is the way to go and you can toss it in the window of car toys when it goes to hell on you and it will:D
im just happy its all working now -without ipod.... still lookin into that.
nav on windshield sort of bugs me.
Update: You may recall this thread was about failures of the factory navigation system, which also takes out audio and A/C controls as well. Mine died sporadically, the dealer replaced it under warranty and all has been well till now.
First, for some reason my new replacement audio system is a Sirius satellite radio instead of the originally supplied XM unit.
Anyway, I was listening to satellite radio and the sound died. The display was normal, just no sound. On any satellite station. Tried FM and Disc and audio worked, just not on Satellite. Got home and tried switching from Satellite to AM. Am came on but then could not switch back to Satellite. Tried FM, and it worked fine. Tried Disc and it worked but the sound was a combination of the disc and (I think) the satellite radio broadcast. Went around the controls for a while trying to get back to satellite until it locked up on AM and wouldn't let me leave.
All this time, the air conditioning worked fine, unlike the last time this thing failed.
Turned the car off, waited a minute and turned the ignition back on and everything worked per normal again except I had lost all my satellite and AM presets. The FM presets were still there. I can't explain it, but they were. The disc changer was back at the start of disc #1.
I guess it's back to the dealer. The vehicle is still under warranty and even if it wasn't, a whole new NAV/Audio/Air Conditioning box should last more than a month.
I'm just throwing this out there for public info. I'm deciding that Toyota or somebody really messed up in the design and execution of this piece of electronics. I just saw a post on a Tundra board where somebody's describiing the same thing in their truck.
dice fools sent me a new whateverthing and ill have car toys put it in again .
since removing the old one no problem other than no tunes
dice fools think its a bad apple well see
good luck all with the nav issue.
i just put in the vais, and it works great. and it bypasses the i agree screen too.
I was just thinking..... If you manually shut off the screen by depressing "Display" to the left of the screen, and then depressing "Screen Off" on the screen itself, you will notice that the next time you turn on the Cruiser the screen will do that - go black. In other words it remembers that you had the screen off when you turned the vehicle off. That is something else that it could be?? This will not display the "I agree" screen before going black, but if you depress "MAP", the "I agree" screen comes up.
