- Joined
- Mar 27, 2003
- Threads
- 70
- Messages
- 1,059
IdahoDoug said:I checked those metal lines over very carefully. In fact, that's why I was laying under there when I first heard the cat boiling noise.
DougM
Doug:
I'm not sure if this is the same as on your truck, but part of the problem with the rear metal hose lines is that they are hidden under the cat heat shields. My hoses were completely shot and I ended up having to cut them off and replace with soft line to the rear heaters. Mine were in such poor shape that I only would have given them part of a season before they blew a hole.
I would think that that much of a loss would start to show, but it could boil off the heat shield as well? Were you able to see the condition of the lines under the heat shield -maybe with a mirror + flex lights?
If you have any doubt and don't feel like doing the work, you could always bypass the rear heater and see if things changed.
This is assuming that the coolant smell in the exhaust isn't a problem.
Good luck
Cheers, Hugh
