Myanmar Shave said:......So far, I have turned the front discs, replaced all of the front wheel bearings, and pulled out the half-shafts, greased and rebooted. the noise has not gone away.....
****.....that's discouraging! If this doesnt fix it on mine, I guess I will drive it till something breaks....
Myanmar Shave said:But if it is a transfer case bearing or something, it could run into the thousands just for parts. I'm gonna keep looking.
Myanmar Shave said:I drained and refilled the differentials and the T-case today. The oil that came out was in good shape, without any signs of a trashed bearing or anything. I also lubed the u-joints and slip joints while I was there.
Pork Soda said:I'll throw in my two cents....
My friend thinks that I should take it to the Toyota dealer, have them diagnose it, say no thanks to the repair, and then do it myself. Like you, I am at my wits end on this.
So what did the Toyota Dealer say?
No, the sound remains the same whether in drive or neutral. My spindle bearings arrived, and I will report back after they are in....Does your car has humming sound when you change to Neutral while driving at high speed too?
