My ramshorn manifolds don't fit so well.....
Dallas
Website
www.octagonmma.com
What should I do to keep them from banging up agsinst the valve covers? On the pass side the dipstick is in the way!
Dip stickcan berlocated or use a different one and the valve cover won't be an issue do the bolt hole line up and how goes theharness??
Check with DomSmith. He has/had same problem and may have a solution/explanation as to why certain ramshorns infringe on valve covers.
you can grind on those bumps if need be if that is what is happening i got mine from a hotrod guy who shaved everything off. that nice black finish has since fallen off as well, mine are a little different than yours.
I had an issue on a different 350 same problem.
I just grinded them down and sent them to jethot for coating.
Looking at it now I think I should knock them off with a grinder. The harness is still on the garage floor awaiting surgery.....all the bolt holes line up!
you can grind on those bumps if need be if that is what is happening i got mine from a hotrod guy who shaved everything off. that nice black finish has since fallen off , mine are a little different than yours.
I know what I would do..... grinder!
