Thanks for the pic. The old heat shield went right on-I'm scared, it was too easy!
I'll give it a shot.
Great thread.
Im currently in the middle of a frame up, and am going with the Mini PS setup.
I have a 69 and understand the steering shaft issues, but knowone has asked about the (pump) bracket mounting on an F engine. Does it go in the same place? What about clearing the alternator and air cleaner?
Does anyone have a thread to point me to, I've been searching all day..
Thx all
Maybe you should eat more bananasI have no idea about anything powersteering, what is this talk about pulleys and gearing, I don't have enough background knowledge to make sense, or use, of your tutorial.
Hey Ken - you used the Mini Truck Pitman Arm? Anybody see any issues there (Doesn't look like it from the thread.) And I guess the FJ40 drag link end went right on to the the ball on the late model Pitman arm?Step 2:
You need to remove the Pitman Arm from the linkage. At the end of the rod, there is a cotter pin. You probably can’t see it with Mud and grease. Once you get the cotter pin out, use a regular head screw driver and screw out the plate. There is then another plate (I used a rubber mallet to move it by hitting the end. Then there is a spring and then a plate that goes over the ball of the Pitman Arm. Having a magnet here is helpful. Note: if you have to use the same Pitman ARM, use a puller to remove it. My new gearbox came with one so I did not need to do this.
17mm according to NAPA. 19mm for AC pump.Go to your local parts store and tell them you want a 11 mm wide by 54" belt.
Someone else chime in on the 11mm wide point if I am off.
You may want to get two or three belts and bring the ones back that don't fit. My local NAPA usually has the best selection.
Good luck
