Tan/Beige in color on State Street in Boise in front of a coffee shop/George's Cycles?
You don't want it! I drove it and there is something wrong with the motor. Valves are definitely loose. Not sure what, but it wasn't making good noises. I couldn't put my finger on it but my 91 with 35s on it has more power. Also, the clunk is pretty severe in that one and there is a gear howl which I couldn't locate where it was coming from. Rear mail seal leak, transfer case is leaking and I think even the tranny is leaking. Front knuckles haven't been maintained and one side is leaking pretty good. PS front window switch doesn't work. Radio doesn't work. Dent in the rear hatch, it doesn't close exactly right. Front bumper is dented as is the lower cowl below the turn signals. DS rear window switch holder broke out. Needs shocks. The heater/AC fan doesn't work on all the speeds. It does have good tires and the new radiator is nice. Sunroof cover was pealing back. Interior wasn't too bad. They spent a ton of money having it detailed. The price was $5900 when I looked at it the weekend before last. A month ago it was $6500. Even if you could get it for 5k it isn't a real good deal in my opinion. Consider you are going to have $350 in parts just to rebuild the front end, and this would need to be done ASAP. The gear howl is most noticeable on coasting. I think with the transfer case leak it is possible that is where it is coming from (read expensive). Cheap shocks would be $100. A cheap radio $100. All of these little things add up. A really nice maintained Fj80 91/92 is only worth the tops of about $6500 (Idaho prices). All these parts would bring you back to that point and you still would have some maintainence issues. I think this rig wasn't maintained all of its life. They've taken care of some expensive issues but they were more of things that needed to be done immediately than things that were done as preventive. It still has the stock plug wires. Non Toyota distributor cap. That is about all I can remember off hand.
