my 91 died on me :(
it died as i was getting off the freeway. it will crank up, but runs really rough and sputters. almost like a 4 cyl with a plug wire off. this happened late last night, so i haven't had a chance to do anything with it yet, but what should i be looking for?
Check the EFI relay and it's wires around the fuse box. I believe there is/was an issue with the wires being a bit thin and a ground wire also having a problem there. The EFI relay is the likely issue. Sounds like yours is on the way out, so perhaps pulling/cleaning the contacts/reseating will get you by until you can obtain a replacement. Generally they simply go and it will not start, so I'll be curious if this turns out to be it.
DougM
i just replaced the EFI relay a few months ago, but i have a spare i got from CD in my glove box. i'll give it a try when i get home
Budd, buddy of mine with a 91 had this continously happen to him. Got to the point he was driving around with a bag full of relays picked up from Radio Slack. He ended up having to rebuild a good portion of his fuse box and some wiring.
If your truck has ever been dunked, you may want to plan on doing the same.
its not the EFI, i tried that at lunch. i'm going to try a compression check when i get home from work. i'll let you know what happens
Coming off a freeway you'll get a normal and significant heat spike as the engine's loaded with heat from the effort, then RPMs drop to idle. This is often the time a vehicle will overheat as well. So, might be a heat-related failure of an electronic component. I'd not bother with a compression check but would do the traditional sequence H noted above. If you need plug wires, I've got a set.
DougM
i did a compression check and the #4 and #5 cyl are between 40 and 50 :(
Ouch, time for a cyklinder leak down test to see if you can determin where the problem is, hopefully it is just a valve leaking, or something else that only requires head rework
here is some reading on making and using one
http://www.xs11.com/tips/misc/misc3.shtml
low compression is an expensive problem. it would pay to get a professional second opinion from a mechanic who is familiar with the 3-FE AFTER you pinpoint what the problem is on your own, weather you are going to do the work yourself or pay ot have it done, if you go in there without your own research you are more likely to get screwed
I've always thought that adjacent cylinder compression problems meant a breach between the 2 in the HG. There used to be a fitting that would screw into the spark plug hole and allow you to pressurize that cylinder so you could change out the valve stem seals while the head was still on. I'd try that on one of the cylinders and then listen to the adjacent one an air leak.
I think you can put a table spoon of oil in the sparkplug hole, then redo the compression check. If it goes up dramatically it is a ring problem. If not, top end still in play. IIRC, of course.
DougM
