Trade My 58 Ragtop bug for your locked FJ80
I have a 1958 Volkswagen Ragtop Semaphore European Beetle in great shape.
Pros
NO RUST AT ALL!!
True ragtop not a Graft
True semaphore also not a Graft
Cb performance manga spark 2 distributor and dry-cell coil with MSD wires
Pro-street transaxle
Mid mount to stop wheel hop
Polished empi 5-spokes
Empi Disk brakes in the front, wilwood 4 piston disks for the rear (new in box ready to mount)
Tach, oil pressure, and oil temp gauges
other than the P/O drilled a hole for the oil pressure gauge, the dash is uncut
interior is complete and in decant shape
Pop-out rear quarter windows
Empi trigger lockout shifter
Transmission converted to later full syncro trans with short axle/short spline
All electrical works including semaphores
Convertible deck lid
Original steering wheel
Original rosenthal vase
One piece windows
Newish tires, the backs have less than 500 miles
2" narrowed beam and dropped spindles
No leaks, roof or under-car.
Let me know if interested located in north New York (FT Drum)
Just noticed my full add didn't post.
Cons
Paint is a 5-10 foot car
Popes nose, decklid, and tail light housings need painted to match
Needs headliner on Ragtop installed, have headliner.
Needs a motor but comes with just about everything to build a 300 hp 2332cc turbo motor. DRD L7T heads, straight cut gears, Webcam 218, 84mm Crank, 3 rods, 3 94mm pistons and cylinders, complete draw through turbo kit with T3 turbo, cold side turbo has oil passages in manifold to prevent icing, Holley 780 double pumper, doghouse cooler, all tin, new alternator. All this needed is a case, crank turned, 1 rod, one P and C, I would just buy new sets that are matched though.
