Build My 1978 Nut and Bolt Frame Off Restoration
Good timing, I just finished cleaning and painting mine. It's the support bracket for the carb fan. Attaches to the fire wall on the driver's side.
Awesome.
Thank you.
Big crankshaft nut and cadmium nut doohickey.
image-jpeg.1321141
Installed with refinished harmonic balancer:
image-jpeg.1321143
Installed timing cover and new gasket from Beno. Also installed main pulley.
image-jpeg.1321142
Heater restore. My 40 did not come with a heater, so I pulled this one from a parts truck. Yes, I realize the lower portion is not correct for a 1978. I may keep it as is, or keep a look out for a 1978 era heater. That being said, I blasted all parts, including the core, which really cleaned up nicely. I'm doing it in dark gray, as this is the color I've seen on unmolested 40s from this year.
All bolts and screws will be replaced with stainless steel. Hinge mechanisms are being blasted and then zinc coated. All rotten foam will be replaced as well.
Rusted vent spring was blasted, and then zinc coated.
The gray paint takes 24 hours to dry, so this side project will not be complete until tomorrow.
image-jpeg.1321530
image-jpeg.1321529
image-jpeg.1321531
Reassembled heater:
image-jpeg.1321585
image-jpeg.1321586
Anyone know what this sensor is at the top of my transmission? I managed to break a wire off of it, and it will be un-fixable due to the loacation of the break. I thought it was the back up switch, but the back up switch (correct me if I am wrong) can be seen in the lower part of the pic, coming off the side with the rubber cover.
image-jpeg.1333288
Carb Fan Restore
Blasted, painted, clear coat, and cad hardware. Even retained factory sticker.
image-jpeg.1321963
image-jpeg.1321964
New fuel filter from Beno along with refinished bracket and zinc chromate screw.
image-jpeg.1322156
Alternator restore.
Pulled apart, cleaned windings and brushes, bearings, etc. Blasted alloy outer cover and painted. Added got rid of the non JIS bolt pictured, and added cadmium JIS hardware, pulley, and cooling fan.
image-jpeg.1322422
image-jpeg.1322423
image-jpeg.1333288
It's an emissions switch. Let the computer know it was in 4th gear.
Awesome. Thank you.
Installed distributor and new NGK plugs.
image-jpeg.1322590
image-jpeg.1322591
image-jpeg.1322592
Rebuilt/restored clutch slave cylinder. Goodbye non-JIS hardware. Hello cadmium. (If you are now reading this, I eventually replaced this unit with a new Aisin unit).
image-jpeg.1322870
Blasted
image-jpeg.1322871
Finished product
image-jpeg.1322872
Wow! Excellent work enjoyed reading thru.......I am hooked!
Heater/blower restore:
Before:
image-jpeg.1323225
Disassembled housing and cleaned throughly. Also gave it a light sanding.
image-jpeg.1323226
Assembled after paint, and new cadmium hardware. Wrapped the wire tie downs in heat shrink. New foam on the flap.
image-jpeg.1323227
image-jpeg.1323229
Finished. Even replaced weathered female electrical connector after cleaning and wet sanding the contacts.
image-jpeg.1323232
Finished charcoal canister, valve, and bracket.
image-jpeg.1324023
image-jpeg.1324024
Nice eye candy my friend!
Clutch master cylinder rebuild/restore.(If you are now reading this, I eventually replaced this unit with a new Aisin unit).
image-jpeg.1324051
image-jpeg.1324056
