Build My 1978 Nut and Bolt Frame Off Restoration
Got my new stainless steel lines from $or. Very high quality.
Spent the morning getting them installed.
image-jpeg.1336751
image-jpeg.1336752
image-jpeg.1336753
image-jpeg.1336755
image-jpeg.1336756
New soft brake lines are going in.
image-jpeg.1337236
image-jpeg.1337237
New motor mounts from Beno. Also started reinstalling the rear wiring harness.
image-jpeg.1337510
image-jpeg.1337511
Got the radiator and fan belts installed too.
image-jpeg.1337767
image-jpeg.1337768
New hoses from Beno.
image-jpeg.1337865
Here's where I deviated from OE Toyota parts. I bought a set of hose clamps from @Racer65 's storefront. These clamps are nearly identical to OE clamps, but are completely made of stainless steel instead of zinc coated steel. I'm really impressed with them.
image-jpeg.1337866
image-jpeg.1337868
image-jpeg.1338003
Thanks for sharing these photos. Amazing attention to detail. The way you're building the truck, it's well above Toyota's original standards. If there's a criticism of the original, it's that Toyota built these trucks to last 20 years rather than forever. After 20+ years all the hardware and metal parts are rusted. Your build will have corrected these shortcomings.
Thank you.
Started rebuilding the Warn hubs.
Before:
image-jpeg.1339792
After blasting and powdercoating:
image-jpeg.1339929
I'll go out later today and buy some stainless steel socket head hardware to put them back together.
Done. Added cadmium nuts and stainless steel socket head bolts.
image-jpeg.1340015
image-jpeg.1340016
Removed front pinion flange and seal. Blasted and powdercoated front flange. (I'm really starting to get the hang of the powdercoater). Also installed new dust deflector, and installed the pinion Nut with RTV as per @Bossman 's instructions.
image-jpeg.1340490
image-jpeg.1340492
Front driveshaft is in.
image-jpeg.1340741
My beautifully powdercoated skid plate is also installed.
image-jpeg.1340826
Took a break, and restored the rear heater.
When I took it apart, it was completely caked in mud and grime. Appeared to have been submerged in the past and allowed to dry. Motor was completely sized. I decided to try and rebuild it, rather than buy a new one. Why? Because that's just who I am!
image-jpeg.1341918
Blasted and powdercoated all of the shroud and outer pieces. Blasted and cleaned out the inside of the core. I'll probably zinc plate the core to keep the steel fins from rusting.
Soaked the motor in PB blaster for a few days, then started taking it apart. Bushings were the culprit; the shaft had rusted to the inside of each bushing. After using a punch, I was able to remove the bushings. I then polished the inside of each bushing with 2000 grit sandpaper. Then mounted the shaft/winding assembly in my hand drill and used the drill as a lathe as I polished the shafts and electrical/brush contacts.
image-jpeg.1341922
Reassembled everything, oiled her up, and gave it a test-fire.
She works!
image-png.1341923
As I stated earlier in the thread, I needed to address my front calipers. I had decided to buy a set of remans, but after looking at prices, and quite frankly the blandness of a reman, I started looking into rebuilding mine. There I go again....
They were pretty nasty to begin with.
image-jpeg.1341924
Disassembled, removed square cut seals, dust seals, snap rings, pins, bolts, o-rings, then blasted the hell out of them. Then wire wheeled the inside of each cylinder. Also polished each piston.
image-jpeg.1341927
Then degreased and painted with high temp silver and a high temp clear coat. Also found new zinc hardware.
image-jpeg.1341929
Ordered a rebuild kit, along with new guide pins, spring clips, etc. Also got a new set of pads, courtesy of another member. Of course added a little cadmium too.
Total cost of rebuild: ~$30 and a few hours of labor.
Finished:
image-jpeg.1341930
image-jpeg.1341931
Got the front calipers mounted.
image-jpeg.1342328
image-jpeg.1342329
Also got to install my new set of OE acorn lug nuts from Beno.
image-jpeg.1342330
image-jpeg.1342331
Installed my new OE hubcaps.
Beautiful.
image-jpeg.1342332
image-jpeg.1342333
Got around to mounting the front shackles.
image-jpeg.1343154
Then a buddy came over yesterday and we installed a new gasket on the inspection cover, correctly installed the DUI distributor (we think....), tackled the rear drums (only to find that one of the cylinders is leaking and will need to be rebuilt or replaced), and we also did the oil galley plug modification.
image-jpeg.1343155
image-jpeg.1343156
Tapped
image-jpeg.1343157
Exhaust blasted, painted, and installed.
img_7989-jpg.1343246
Decided to blast and powdercoat the valve cover too.
img_7987-jpg.1343247
img_7990-jpg.1343248
If you decide you want to rebuild let me know. I have two rebuild kits from cruiser outfitters that I ordered and then decided to go all new cylinders. I can send a rebuild kit to ya for just shipping (6 bucks for a USPS small flat rate). Depending which one it is I might have a rebuilt one too (I rebuilt two then found the other two were no good)
otherwise its looking great!
Hard fuel lines ready for installation. Are they new? Nope. Lots of elbow grease, and a high temperature clearcoat. I think they turned out beautifully.
img_7994-jpg.1343665
Installed
img_7996-jpg.1343804
img_7997-jpg.1343805
