My 100 Series Build Thread (1 Viewer)
LA
Hi everyone. I'm fairly new to the forums. Was pining after a TLC for a long time; back in February I finally found one. I'll document here what I can about the truck, including what I paid, some history, and my baseline efforts. Hopefully it can help someone shopping around, or someone that is new to our forums looking for some guidance on baselining. Anyway, welcome to my TED Talk.
I bought the truck in February of 2024. This 100 series is a California native. Sold down in San Diego back in 2002, it was driven by someone for about 3 years before they sold it to the second owner, who then owned until 2024, when I (the third owner) bought it. It had 203k on the truck when I got it. The previous owner seemed to take pretty good care of it, but not to the point of coddling (he was a family guy with two kids that grew up going on camping trips with this thing). So, once I made the trip from SF back to LA (which went just fine), I set out to start baselining it.
Here is the list of items that I've done so far (note that this is not really my 'daily', but I do drive it 3-5 times a week):
204000​
204120​
204120​
204300​
205000​
205200​
205500​
206240​
206500​
206600​
206710​
206720​
Maintenance Item
Engine Oil - Mobil 1 Synthetic High Mileage 5W-30 (7 quarts)
3/8/2024​
8/11/2024​
Transmission Fluid -
Rear Differential Oil - Valvoline 80W-90, ~3.5qts
3/8/2024​
Spark Plugs -
3/16/2024​
7/7/2024​
Ignition Coils
Air Filter - 17801-50040
3/8/2024​
8/9/2024​
Fuel Filter
Wipers -
8/9/2024​
Rear Tires - 285/75/16 BFG KO3; note this is the largest tire that is widely agreed to fit without a lift; old size was 275/70/16
8/9/2024​
Front Tires - 285/75/16 BFG KO3; note this is the largest tire that is widely agreed to fit without a lift; old size was 275/70/16
8/9/2024​
Brake Fluid Flush
4/25/2024​
Front Diff Oil - 08885-02606
3/8/2024​
Valve Cover Gaskets - 11213-50031, 11214-50011, 00295-00103, 11193-50010, 90080-10330
3/16/2024​
3/17/2024​
Transfer Case Oil - Lucas Synthetic 75W-90 Gear Oil
3/9/2024​
Grease Zerks - Valvoline Multi-Vehicle Moly Grease Tube, front and rear of driveshaft
3/8/2024​
PCV Valve
3/16/2024​
PCV Hose (driver) - 12261-50050, and heat shield for PCV valve 12236-50010
3/30/2024​
Heater Tees - 87248-60460x2 (these appear new, so into the glovebox they go)
7/30/2024​
PCV Hose (passenger) - 12262-50080
4/13/2024​
Air Hose (on driver side, long boi) - 1734150110
3/30/2024​
Air Hose assembly (one plugs into air intake, one into intake manifold) 17030-50070
4/13/2024​
Radiator (CSF)
4/25/2024​
Power Steering Fluid Flush
4/25/2024​
Tighten/Adjust E-brake
4/25/2024​
Diff Bushings (front support, support, cushion, stopper (x2))
4/25/2024​
Replace upper Idler pulley, and serpentine tensioner pulley
4/24/2024​
Hub flanges, cone washers, and gasket (driver's side), used 'D' snap ring ~2.38mm thk., 43421-60030
5/31/2024​
Hub flanges, cone washers, and gasket (passenger's side), used 'D' snap ring ~2.38mm thk., 43421-60030
6/1/2024​
Water Pump/Timing Belt, Idler Bearing, Drive Belt, Tensioner Bearing, Cam seals, crank seal, t-stat, t-stat gasket
7/30/2024​
Fan Clutch rebuild
7/30/2024​
Fan bracket
7/30/2024​
Rack and Pinion bushing kit
Inner tie rod
outer tie rod
front shocks
Rear Sway bar bushings - 48815-60140 - bought from trail tailor, note that the rear ones are slightly smaller in ID than front
8/17/2024​
Front Sway bar bushings - bought from trail tailor
8/26/2024​
Rear sway bar end links - bought from super pro
8/17/2024​
front sway bar end links - bought from trail tailor
8/25/2024​
Engine cover No. 2 (bottom of truck where the plastic shield has one ear broken off) - 5142060010, on partsouq
Thanks for sharing. any further plans with it or keeping it mainly stock?
You’re welcome. I plan on keeping it mostly stock. No lift or anything like that. Next things on the list are CV joints, followed by suspension work like UCA and LCA. Once I knock those out, i think I’ll finally spend more time enjoying the trips than fixing her up. Don’t get me wrong, the tinkering is fun, but it has its limits, and ultimately I bought the truck to drive, not wrench on!
Man thank you so much for sharing! I'm a new owner of a 2007 with ~204k -- it had a robust maintenance history so lots of the preventative stuff has been done, but I definitely want to stay on top of it-- wish I had the video "how to" for all the things you performed above!
This time I remembered to get a Blackstone report for the oil change - see below. I wonder if there is a thread elsewhere comparing oil reports for the 2UZFE...
