Guys,
Has anyone considered a multi fuel conversion for the 100? These are 6.2 and 6.5 engines with mechanical IPs (injection pumps) that can run about any fluid that will burn. The newer 6.5s can be converted to mechanical IPs.
I think if you could get 250 hp and 400 ft lbs of torque, you would be good to go and once again, run anything as a fuel, diesel, gas, kerosene, atf, etc.
More info below.
https://forum.ih8mud.com/diesel-tech-24-volts-systems/603899-multi-fuel-military-diesel.html
Multi fuel Range Rover
http://www.expeditionportal.com/forum/threads/71412-Range-Rover-P38-diesel-conversion
We need to get this figured out.
More info below.
