all Im after is to make the engine more efficient. I know it is limited on power but there is still some potential. After the muffler I put in 91 octane and felt a good increase in power and my mpg avrged 13.5 from 12. Makes me think about raising the compression a little and maybe some light porting.
I'm with JohnHeld on this one, like water from a stone. If "all" your after is to make the engine more efficient, the exhaust isn't going to do that alone. The 91 octane helped you more. IME, all engine mods are bang 4 buck, and eventually point at the original Mission Statement. If raising the compression gains you 10% power and costs you 1000USD, that's 50$/HP. If porting gains you 1%, and costs you 100, that's 50$/HP. It's cheaper $/HP to put on a SC or a turbo kit.
"Feeling" power is deceiving, butt dynos are notoriously uncalibrated. Start a thread, but baseline it with some data, that will help you and others understand the trade-offs. Playing with a N/A truck? Best bang4buck is the timing. Toyota is known to be very conservative on timing maps, and the tables are linear to baseline = change baseline timing when running higher octane fuels (BTDT).
Exhausts? See my thread... You will be exchanging noise for 'feeling' faster using a glasspack. Is a glasspack quieter than just deleting the rear resonator and dumping the pipe? BTDT, it's 'quieter', like a 20guage shotgun is quieter than a 16guage. And on a N/A stock engine, increasing exhaust flow on a motor tuned for torque, *on a dyno* usually shows a slight bump in HP at the expense of a decrease in torque.
If your exhaust is failing, you can start down the slippery slope, btdt. If the exhaust is just not loud enough, you can start down the slippery slope, but climbing back is expensive. The easiest thing to do, is leave it alone, and save your money for the SC or the turbo, which will then cause the exhaust to fail... Then start the slippery slope out of necessity, not theoretical desire..
HTH, IME, IMO
Scott J
94 FZJ80 Supercharged 3in downpipe back
https://forum.ih8mud.com/80-series-tech/538482-sumotoy-multiple-exhaust-installs-long.html
