Hi
Need some ideas. I am trying to mount a 94 amp Delco 12si in a 71 FJ40. I am running a winch a lot and the 40amp original has a hard time keeping up. I am having a problem with the lower mount. The alt is mounted down low on the drivers side. I have included a pic with the alternator next to the mount in the position where the alternator, crank and water pump pulleys will all line up. I have seen a couple of Universal Alternator brackets on ebay and amazon and it kind of looks like they are trying to solve the right problem. They are intended for mounting alternators on old tractors. None of them have dimensions so it is hard to tell what will work (A200 is an example). They look kinda wimpy and are a little expensive.
http://www.amazon.com/Tractor-Gener...-1&keywords=a200+universal+alternator+bracket
Has anyone used anything similar? I have not ruled out of moving it to passenger side to get it out from under the exhaust manifolds. Wiring is not really an issue. Any ideas would help. I am about ready to just fab something.
John
John
