Hey Team,
I need to replace my motor mounts, and I'm debating between lifting the engine from above or below. From below seems easier and perhaps safer. If I use a floor jack, I would use a bag of salt or sand to spread the load over a large surface area on the underside of the oil pan. If I come from above, I'd be buying a Harbor Freight engine hoist (2 ton variety).
What say you on which way I should tackle getting the lift required for this job?
Thanks
Russ
Thanks
Russ
