I'm wondering what I'm missing here. Recently installed a Yakima roof box on my '00 with the standard (short) roof rack and OEM rails. The mounting points for the box are solid, but there is a surprising amount of flex/movement in the OEM rails even with the box unloaded, both while driving over rough roads or if I manually initiate movement.
The thumbscrews are tight on the ends of the bars into the rails, but I don't see any other way to tighten the assembly down, and it would appear that the rails themselves are flexing. Would that be normal?
I'm about 2 feet away from going the 8020 route, as I'm not sure I trust this rack with the box loaded at highway speeds.
For anyone who has had this issue, did you solve it? Or did you go to an aftermarket rack/rail system?
Thanks
Thanks
