More Confusion on OME A vs B Side
Romance, MO
Cruiser is back in the shop to get the A spring swapped to the PS and B to DS. Recall I got 3" lift on PS and only 2" on DS.
Shop calls and says they talked to ARB and were told they did it correct...A on DS.
I called ARB and was told there is a lot of confusion but the B spring is the longer and needs to go to the DS!
I called the shop back and told them to swap them.
I sure hope the dern thing is close to level when I get it back! It is amazing how much lean there is with only a one inch difference!
Geez...I wish ARB would stop fawkin' around with the labeling.
Tall springs on the left side (U.S. Driver's side)
So the shop calls me...did the swap and the Cruiser leans just like before! I call ARB to order a complete new set of springs. About ready to give the credit card # and I decide to hold off until I get a look at it in the flesh.
Go pick it up after work....looks good??? Put a tape on it....exactly level in front, only 1/4 inch off in the rear! This is measuring from the lower lip of the wheel to the bottom of the flare.
So happy, I stopped at Discount Tire on the way home and got a set of 295-75/16 BFG AT mounted!!
I'm 'cruisin!
Thank goodness the madness is ending. Stop the insanity. Funny thing is hasn't ARB changed the label like 3 times in just the last 2 years? Yes, folks still don't get it.
