- Thread starter
- #41
Greg B said:Well, Shotts said it was a "Wish List" so I threw the Truetrac's in there. The reason I like them is they are gear driven, well built and strong and have very few parts to fail (no airlines or electical connections). Also, because they are a limited slip design, they are very smooth on road. The sweetest thing about them is that they can be activated by brake modulation. On a 100 with traction control, they activate automatically because the TC uses brake modulation to slow the spinning wheel. This in turn causes the Truetrac to kick in and give traction. It works really well on LR Discovery series II, which uses a similar design. The only problem is, they aren't made for a 100, and because of small market, I doubt they ever will be.I've already contacted Tractech and Quaiffe and neither company has plans to build a LSD for the 100. So, I'll probably go with ARB's when the gears are available.
As far as the tire carrier goes, I'm thinking about working on that and a set of cargo drawers for the rear this spring/summer. The design in my head so far is to build a cage that bolts to the frame and then have the skid plate hinged at the front so that the plate can drop down to remove the spare from the rear. Once I start building, I'll post some pics. Any of you vendors out there want to build something like that, I'd be interested. That way, I don't have to spend a lot of time fabbing one up.![]()
Greg
'01 UZJ100
I myself wouldn't switch from an open diff when unlocked. I'd be skeptacle as to ride quality and TRAC effectiveness (meaning if TRAC can truly be in 100% control instead of an LSD). Of course I have no basis for this opinion. It would make for a interesting test if it were possible.
Other than ARB, my preferance would have been to add 2 electric lockers (open when unlocked) though they are not offered and only if they locked and unlocked fast like the ARB's. (I do not like my 80's factory lockers after having ARB's) I cannot fault an ARB/TRAC combo whatsoever and I wsh for nothing at this point (exceot a BIG air compressor for the tires
