mod light question (1 Viewer)
Well I'm trying to do this mod.
http://www.sleeoffroad.com/technical/tz_indicator.htm
My local store guy was nice but had no idea what plug I was looking for.
(The plug that we used is a CALTERM 08584 GM 908 degree angle Socket. This was bought from our local parts store. It is important to get a 90 degree plug with a thin outside dimension. If this is not done it will not be possible to install the light housing.)
Its the one about half way down.
My chevy dealership stoped talking to me when they found out I wanted this part for a non chevy. He said to me ( Ovbviously you down loaded this from the net why don't you ask them) while he pointed to the HTML at the bottom of the page.
I know Slee is buisy with his new shop so I was hoping one of you have done this and can help find the plug
My local shop parts guy needs to know what vehicle this plug is for maybe year range. It is for a marker light right?
Any help would be appreciated.
Steven
Get a socket that holds an 1157 and stick it in the hole that is already in the lamp...;)
Mine work yummy..........................:D
Is this part something I can order from Toyota, If so do you have a part number so I can add it to my growing list?
Buy the way Thanks! My Taco's starter is fixed :D
Steven
Thanks Dan
With the bulb # the parts guy took me right to a rack with several chose's.
Well the drivers side went good, on the passenger side the two signals were flashing opposite each other. I disconected the jump wire from the running light going down to the turn signal and connected it up to the white wire on the blinker light. The running light didn't even light up then.
So I Moved the wire back to the green wire off of the blinker, tested everthing before I solder'd Tested again when I was done, before I put the lenses back together, and after I finished assembling everthing, It worked right.
My wife wakes up and checks on me at 2 in the morning and I want to show off. I turn on the signal and there opposite again. :mad:
does my flasher need upgrading?
Steven
Steven
:flipoff2: Can you just wait til the next day? :flipoff2:
1st of all... How many blinker you need in the front? 2 on each side?
Thats what I did :D
