Mixing Toyota AHC fluid (Part# 08886-81221) with Toyota AHC fluid (Part# 08886-01805) (1 Viewer)
Western NC- Hour North of Asheville on the BRP
Are the old and new Toyota fluids fully compatible-- can you mix them in your system?
I have read about four long threads on sorting and tuning the AHC system on my '05 LX470 but I am not clear if the New fluid has been reformulated thus the newer part number- or if just the part number was changed.
I am going to perform a PADDO flush which flushes out a good portion of the old fluid - but perhaps not all.
I am not sure which fluid is in my system so I felt I better confirm.
As best I understand, the different numbers relate to different packaging of the same fluid:
Toyota/Lexus Part No. 08886-01805: This is a 2.5 litre steel drum of genuine Toyota/Lexus AHC Fluid. It is the longstanding and current format I buy in Australia (and which shows recent dates when I buy it).
Toyota/Lexus Part No. 08886-81221: This is a 1 litre (1 quart?) plastic bottle of genuine AHC Fluid which seems to be the common format distributed in USA.
The fluid in my steel drums is produced for Toyota/Lexus by a large Japanese oil company, Idemitsu Kosan Co., Ltd -- this is printed on the drum.
I can see website pictures of the labelling on the plastic bottles -- these show the same maker and source of fluid.
I am not aware that there is any difference in the actual Fluids.
You may wish to call or e-mail Idemitsu in USA for further details. They should be able to confirm whether or not the Fluids are the same in both cases.
Thank you-- I also believe it is a package change with the same- or at least fully compatible fluid-- or else there would be a warning on the liter bottle.
I just wanted to be very sure since I will not be performing a full flush this first time due to a very painful spine issue.
I am going to pull out the old fluid from the reservoir and put new in since I cannot get on my back to bleed the globes and the accumulator.
Same fluid, different packaging.
