Ok, seemed cheap, ordered one on Ebay to test and open up. Arrived today.
So, open it up and here's some observations.
1) Draws about 7mA (depending on combination of segments on the leds, e.g. 13.8 will draw more than 11.1, less segments lit on 11.1).
2) Accuracy is decent, if voltage is say 12.44V it will display 12.4V, if voltage is 12.46V it will display 12.5V. Same accuracy both channels. This measured with a precision powersupply/meter.
3) Not particularly bright since the 'frosted' lens does attenuate the light output, but then it also improves segment contrast.
4) The unit stock will operate if either MAIN or AUX has power connected. It uses a simple Diode-OR circuit to combine either battery to run the regulator in the unit. Easy to remove the Aux diode if desired and then the unit will only operate if there is power on the Main input (i.e. ignition switched Main input).
5) Benefit of removing the Aux diode is that if you feed the Main input from ignition switched, then the display/unit will turn off when you turn the key to off. Current draw from the Aux battery in that case is only 0.2mA, and obviously 0mA from the main since there is no power with ignition turned off.
So, here's the modification process. The unit can easily be opened by pushing 2 clips on one side in and then 2 clips on the other side in and the back cover slips off. NOT ultrasonically welded close etc - so 'mod' friendly.
Pictures:
To remove I just added a little solder to the soldering iron tip, heated one end of the diode then the other, then back again and then it slipped off the board. Easy to add back in if ever desired.
Overall picture:
cheers,
george.
