- Thread starter
- #21
Not very scientifically. The guy doing the work has built a lot of diff and is a mechanical engineer that now operate a cruise shop. I’m definitely more anal retentive than he is with procedure and torque specs. Causes some discussions and eye rolls both ways.How did you decide how much to tighten the pinion nut? When you say "feel".. you mean pinion preload feel? How much torque did it take to tighten the nut? (ie, did it seem like you were still crushing the sleeve?)
Anyway, to answer your question, we just incrementally hit it with an impact then rotated the flange back and forth until he was happy. We did not pull the rear tires, or put the truck in neutral, which may have been what we should have done but when I’ve done essentially that in the past to just rotate the drive shaft, it takes a lot more than 12 in-lb to rotate the drive shaft flange. I think you’d have to pull the axles to have a shot. I’m fairly certain, if we had tries to get a measured 12 in-lb, we would have still had slope and noise. Could we have over tightened it? Yes, though the tell tail whine while decelerating, of a loose/bad pinion bearing is way better but still slightly there. I’m hoping this means we didn’t over tighten it and the diff is serviceable enough to make the Moab trip. But, the reality is that there is no way to know this other than pull the 3rd and doing this the right way.
) and even if you talked them into it I doubt they would warranty it.
