For Sale Menifee, Ca: 2012 Nissan Xterra Pro4X Overland Build (2 Viewers)
Menifee, California United States
Outside Link
https://curatedbid.com/product/2012-nissan-xterra-pro4x/
We’ve posted a couple of nice Xterra builds in the past but this may be the nicest. One was a Pro4X like this one and the other had the Titan front diff swap. This one has both! The Pro-4X trim is so rare that even Motor Trend stated that they had never heard of it when initially reviewed. It came from the factory with a locking rear diff, skid plates and off road tires and dampers. This particular Pro-4X is very low miles (43k) and has been extensively modified (see below), including: the Titan front diff, upgraded drive shafts and U Joints, wheels, tires, ARB Air Lockers Front & Rear, ARB Twin Air Compressors. Dirt King long travel Suspension, roof top tent and fantastic looking fiberglass front fenders. Check out the build details and photo gallery and ask us a question if you are interested.
Vehicle:
  • Year: 2012
  • Make: Nissan
  • Model: Xterra Pro4X
  • Drive: 4×4
  • Miles: 43,500
  • Fuel Type: Gasoline
  • Transmission: Automatic
  • Engine: 4L V6
  • VIN: TBD
  • Exterior Color: White
  • Interior Color: Black
  • Title: Clean
  • Price: $44,700
Details & Upgrades:
  • M205 Front differential out of a 2008 Titan. Fully rebuilt prior installation by Differential & Axle Shop in Escondido.
  • 4:56 gears
  • Upgraded drive shafts with 1350 U Joints
  • Method 17 wheels with Titan Bolt pattern
  • 5 Toyo MT’s in 35-12.5 R17
  • ARB Air Lockers Front & Rear
  • ARB Twin Air Compressor with tank
  • Dirt king complete long travel kit with Titan OEM factory axles
  • Rad flow 2.5 coil overs with 700lb springs, reservoirs, and compression adjusters
  • Fox Hydraulic bump stops
  • OEM Titan: brake, rotors, knuckles, spindles, wheel bearings, calibers master cylinder and brake booster
  • Fiberglass front fenders
  • CJD full titan steering rods and heims
  • Shrock Works front bumper with Smitty built winch
  • Shrock Works Rear bumper with tire carrier
  • Alcan full rear leaf pack 1000lb over stock
  • Radflow 2.5 shocks with remote reservoirs and comp. adjusters. Sumo Springs Rear Bump Stops
  • 2 Rear wheel spacers to match the bolt pattern and width of titan swap
  • Heavy Duty Nisstec Adjustable shackles
  • American Off Road Skids
  • ARB rear Diff Cover
  • Shrock Full underbelly steel skid plates
  • American Off Road fully welded rock sliders
  • Full Dual Battery Setup with brand new optima yellow tops
  • Painless Battery Controller Switch interior mounted
  • S-Pod (6) Switch Wiring Lights, Compressor and Lockers
  • Rear custom storage deck
  • ARB Fridge with Alu-Cab Fridge Slide
  • Alu-Cab Gen 3.1 Expedition Rooftop tent with Side Rain Cover and Custom Mattress
  • Alu-cab Shadow 270-degree awning
  • Alu-cab shower cube
This is a great build! One of the best Xterra's I've ever seen. Too bad it's $10k over my budget or it would be sitting in my driveway but it looks like very fair price for what you would be getting. GLWS
