Full Toyowest Recommendations (in no particular order):
TUNE-UP, PERFORM COMPLETE MINOR TUNE-UP REPLACE SPARKPLUGS, INSPECT ALL
DRIVEABILITY RELATED COMPONETS, ADJUST CURB IDLE SPEED AND IGNITION TIMING (IF APPLICABLE) PLUG, IRIDUM
REPLACE IGNITION CORD SET, INSPECT ALL ASSOCIATED COMPONETS WHILE APART. REPLACE DIST.CAP(S) ROTOR(S) AND WIRE(S)SET
PRESSURE FLUSH POWERSTEERING SYSTEM COMPLETE. INSPECTHIGH PRESSURE AND RETURN LINES AND HOSES.INSPECT ALL POWERSTEERING SYSTEM RELATED COMPONETS. COMPONETS FOR PROPER OPERATION. FLUSH, KIT P/S
THROTTLE BODY SERVICE: PERFORM COMPLETE THROTTLE BODY SERVICE,CLEAN ALL CARBON DEPOSITS ON THROTTLE BODY BUTTERFLY VALVE INSPECT ALL LINKAGE,CHECK THROTTLE POSTION SENSOR(s) INSPECT ALL RELATED COMPONETS FOR OPERATION.
REPLACED CRACKED SPLIT AIR BOOT WHILE APART
REPLACE FUEL FILTER ELEMENT,CHECK ALL LINES AND HOSES.
FRONT BRAKE JOB TOY: PERFORM COMPLETE FRONT BRAKE JOB RESURFACE ROTORS,
REPLACE FRONT BRAKE PADS, PACK FRONT WHEEL BEARING (4WD)LUBRICATE ALL SIDES INSPECT CALIPERS AND ALL HARDWARE AND RELATED COMPONENTS.
ADJUST VALVES REPLACE GASKET AND GROMMETS.
TRANSMISSION FLUID FLUSH
ERFORM COMPLETE TRANSMISSION FLUID
EXCHANGE PRESSURE FLUSH SYSTEM COMPLETE. INSPECT
COOLER LINES AND HOSES.INSPECT THROTTLE DETENT CABLE. ROADTEST VEHICLE FOR OPERATION.
SERVICE TRANSFERCASE ASSEMBLY, DRAIN AND REFILL ADD CONDITIONER.
FLUSH/BLEED BRAKE HYDRAULIC SYSTEM,INSPECT ALL BRAKE LINES AND HOSES, INSPECT
ALL RELATED HYDRAULIC COMPONETS.
BRAKE FLUID FLUSH
REPLACE OIL PRESSURE SWITCH, ASSEMBLY
POWER FLUSH COOLING SYSTEM ,INSPECT ALL BELTS HOSES, CHECK ALL RELATED
SYSTEM COMPONETS FOR PROPER OPERATION.PRESSURE TEST COOLING SYSTEM CHECK FOR POSSIBLE LEAKS.
REPLACE DRIVE BELT(s):REPLACE DRIVE BELT(s) INSPECT ALL PULLEYS AND ASSOCIATED COMPONETS.(INSPECT ALL PULLEYS, A/C BELT IS OFF INSTALL BELT AND CHECK SYSTEM
REPLACE SHIFTER BUSHINGS
REPLACE FRONT TRUNION SEALS, INSPECT BEARINGS WHILE APART, INCLUDE COMPLETE DISASSEMBLY OF FRONT AXLE ASSEMBLY RPLACEMENT OF ALL INNER AXLES
REPLACE ENGINE OIL PAN GASKET, INSPECT OIL PAN WHILE APART
SERVICE REAR DIFFERANTIAL ASSEMBLY DRAIN AND REFILL ADD CONDITIONER., SERVICE
BREATHER WHILE APART
REPLACE REAR MAIN OIL SEAL, REMOVE TRAMSMISSION ASSEMBLY TO REPLACE ENGINE
REAR MAIN OIL SEAL.INSPECT ALL ASSOCIATED COMPONETS WHILE APART.
REPLACE FRONT AND REAR SHOCK ABSORBERS,INSPECT ALL RELATED COMPONENTS
WHILE APART.
FRONT CRANKSHAFT SEAL:REPLACE FRONT CRANKSHAFT OIL SEAL(WHILE APART)
