Searched and just found mentions of it. But I'm looking for a specific length to place the weld so I know I'm close.
The more i think about it, it should be the same as the mini trucks...right?
stolen from pbb
stolen from pbb
Martack - See 'Birf Stuff' above for more info on this....
The easiest way to find the correct location for a Martack is to put tape on the spines of the axle shaft and insert the axle into the housing while watching the seal location. And keep moving the tape until you found the correct position.
http://www.pirate4x4.com/forum/attac...postid=1537731
Also note that after tacking the splines you wil have to carefully grind them doen flush so the axle will slip into the spider gears/locker all the way to the tack. Another way is to grease the splines but for me that has never worked as good as using tape. You want to place the tack weld so the axle can not slide into the diff to causing the seal to leak diff fluid into your knuckle. This is also used with aftermarket Birfs so you can remove the outer most clip to add in removal of the axle from the birf n the case of trail breakage.
Another think tha tis important to note is that you SHOULD measure this distance on you axle and not following any one elses dimensions becasue there are too many variables to only use on tack weld location for all set-ups.
Quote:
Originally Posted by 4RnrRick
Here a sketch that I did quickly to show you what my understanding of what a Martack does.
The top version (factory) allows the axle to float a bit on the axle spines in the diff due to tolerances and expansion or contraction due to the change in temperature.
The version on the bottom allows the axle to float a bit in the star of the birf and the splines in the diff to tolerances and expansion or contraction due to the change in temperature.
And here is the Camo Method.
This verson allows the axle and Birf assmbly to float a bit on the brass bushing inthe spine, on the splines in the star of the birf and the splines in the diff to tolerances and expansion or contraction due to the change in temperature.
