Has anyone seen a write-up on an install for the Mark's 4wd speedo correction. I DID search on here and Slee's site and have not found anything. It's a fairly simply install, I was just curious where you guys mounted your conversion box and where/if you drilled a hole in your tunnel. Someone had mentioned that you could use an existing hole or rubber plug??? Anyhow, thanks for the help.
