I was going to change out the tranny oil today with Castro Syntec from Wallymart. Can't beat the price but ... then I got reading and now am pretty much totally confused (and procastinating). Some say only use sythetic gear oil designed for synchro transmissions because it needs the modifiers for the synchros to work right. Others say don't use synthetic gear oil for transmissions because it has the modifiers for LSDs and will screw up the tranny. I had wanted to put synthic in just for smoother shifts when is is cold and to be able to get going right away when its real cold. Below -15C it can be a pain to even get 1st gear unless I let her idle for about 5 min or more at 1400 rpm.
So I thought I'd ask the guys I do know rather than going by the conflicting advise in the outernet from people I don't know. FSM only says 75/90 GL4 for the tranny and T-case and 80/90 for the difs but nothing about synthetic oils So, which synthetic oil for the tranny do I get and where do I get it? Or should I just put in some more dino 75/90 and put up with a cold tranny issues.
Right now I have a jug of dino 85/140 for the rear lsd (with as tube of the lsd friction modifier) and a pail of dino 80/90 for the case and front dif.
