Manual transmission reverse issue (1 Viewer)
Sudan
Hello everyone,
I have an issue on my Toyota 2007 gearbox, difficult to change it to reverse gear unless I use the first gear then change it to the reverse gear.
That is a plastic shifter seat problem in the manual shifters. Is a 5 buck part, accessible from the shifter boot side. In the 100 , not sure.
The shift seat bushing is accessible from top side of the transmission inside your truck if the transmission is an H151F.
How old is the clutch plate/disk? and pressure plate. When the engine is off, can you shift into reverse as normal? If so I think the clutch disk or pressure plate is on its way out. Also check the hydraulic fluid, may be its leaking and is not disengaging the clutch properly.
