Good day, all knowing brethren.
So I'm looking to install a manual boost controller into my 1KZ-TE to up the boost to hopefully deliver some more power.
I have already installed a front mount intercooler, 3 inch exhaust, egr delete, so I'm not too worried about additional heat. I have also just replaced all the injectors, glow plugs, and fan clutch, so things under the hood should be running fine.
Have any of you already installed a manual boost controller? Is there a specific model I should be looking at? Other than keeping boost under 14 psi to not affect the CPU fuel cut off, is there anything I should be looking at doing, or not doing that someone has already trouble shot along the way? Is there a way to cut around the 14 psi max and get more without things getting iffy?
Thank you for your time, ladies and gents, I do appreciate the shared knowledge.
B
B
