I'm about to order a man-a-fre u-bolt flip kit, anyone has some bad experience with those? Did any broke something, like the rear suspension pin.
I'll be installing them with a new set of OME spring
In top two photos in post #12 ---
On the rear axle - it looks like one could mount a shock pin in the hole on spring perch and relocate the shock up out of the way.
Next time I might buy two sets of fronts.
Yes, good point.They offer the earlier rear set....If you purchase fronts, there will only be one top piece in the kit that will work, the other will need to be modified as it is two different lengths to compensate for the diff housing section of the front axle...
