M1101 build
Texas
Well this thing has made it's way back around to me via a buddy. It's a Schutt M1101 trailer like all of the tan/green carc painted ones you see from gov liquidation auctions. This one was never put into service, it was bought as a contract overrun new from the factory and the general use contractor style topper was built for it by a now defunct upfitter. Short of the twin 20# propane bottles on the front and the rear hitch receiver, it's exactly how it was purchased a few years back. Right now it sits on the military standard 37's with double bead-lock wheels and the noisy pintle-lunette setup.
Here are my plans for the build:
  • Ditch the 5" drop straight axle in favor of a Timbren Axle-less suspension
  • Abandon the hydraulic surge brakes for full electric
  • Change the pintle-lunette setup for a Lock-N-Roll hitch
  • Add a screened sliding window on the drivers side where the front tilt-up door is
  • Build aluminum shelves the depth of the inner wheel well on the passenger side to allow for storage inside the flip-up doors on that side (kitchen/fridge)
  • Enclosed trailer style roof rack for use with kayaks and possibly a RTT should it ever be needed
  • 270 degree awning on the passenger side to cover the passenger side flip-ups while using the kitchen and it'll cover the rear doors for the entrance into the trailer
  • Straight out awning on the drivers side, when combined with the 270 it'll be covered on three full sides
  • Water tank beneath the trailer, likely in the 20-30 gallon range, plumbed with a pump for use as a wash down and for the shower
  • Shower awning/enclosure on the front passenger side
  • The interior will be insulated for sound and thermal and siliconed at all junctures, holes, gaps etc. to limit dirt/dust intrusion and then finished out in some way
  • Lights and a two-way fan installed inside, I plan to skip a dedicated battery system and have everything run to my Bluetti portable power station
I hope to get started on this soon and work on it in stages in my free time in hopes of having this completed by years end.
@Tex68w did you make any progress on this last year? I've got an m1102 sitting in the garage that I'm planning to make my 2024 project.
A buddy took it off of my hands and then subsequently sold it. I sold the 200 as well and I am now in process of getting a FWC for part time use in my F250 Tremor that replaced the 200. We still have the GX460 and will likely grab the new GX550 Overtrail in year two.
I have one that the rag top is becoming shredded from sitting out in the weather and full of Land Cruiser parts.
When my FJ40 build is complete I will start on converting the trailer and tow with my 40. I hope I can back it it better with it then with my Ram3500. It is easy to move around with my John Deere and the 3point hitch.
I noticed that my tires are rotting and looks like one is sitting on the run flat. The price of 95% take off is about $200. Then not put the run flat donuts back in but would still have to run 2 spares.
I am trying to find the right part numbers for Dexter hub and brake drums so I can convert to 6 x 5.5" and get two more rims to match the rims on my 40 and would not need 2 different spares and cut down on the weight.
Thanks,
I am familiar with Steel Solders and through them found H1 tires are rims and how to remove the donut. But it just makes sense to run the same tire and rim as on my Land Cruiser and only need 1 spare as well and reduce the weight.
Here’s the IH8MUD version of the Military Vehicle world:
M1101 & M1102 Trailer TM’s:
Thanks for the link for the manual. GE and Nuke procedures/work packages are much more complicated then the work packages in that manual. I like the Toyota manuals even better it has specs and tolerances and SST numbers.
I was able to find replacement bevel gears for the tongue jack through Steel Solders.
