LX570 Prinsu rack and lightbar
Scottsdale, AZ
I finally sucked it up and weathered the 100+ weather to install my Prinsu rack. Surprisingly it went on very easy. No need to drop the headliner. I also installed a 43” Dual function Amber/white light by Cali Raised. I have the wind faring cut and the light installed but not wired up yet. I decided to make my own wiring harness since the light needs two relays, one for amber lights and one for white.
Does the front tip of your Prinsu vibrate at high speed?
I had to drop my wind fairing much lower than you have it now.
also, I don't see your wires. Where did you run them?
I will tell you after today when I drive on the free way. I may have to drill a hole if I want to get the fairing closer to the roof.
As for wiring the light...this light has the wires come out the left side so I am running it behind the faring. I haven’t finished wiring so my intention is to run it down the drivers window. That was the recommendation from Blake at Cali Raised.
Yep, I did both of those things ( new hole and wires in driver side C channel)
I like this look. Any downsides since installment? Can you mount lights on the side/ rear of the rack? Thanks
