LX470 - What oil for TXFR case (1 Viewer)
My very rusty memory is telling me the Transfer Case behind the Auto box uses Auto fluid, not regular heavy gearbox oil.
I cannot find a reference anywhere for the correct oil.
Does anyone have a reference for the correct fluid type and fill volume?
Thanks
Paul
I used synthetic gear oil. Search the forum. I know for sure it's listed somewhere on here...
Lexus' website has an online owners manual. I just changed mine. It is gear oil, but I don't recall the weight.
Recommended by Amsoil. Using a good synthetic by other manufacturers accomplishes the same.
1999 TOYOTA LAND CRUISER 4.7L 8-cyl Engine Code 2UZ-FE
Recommended Products
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SL
Maximum Performance SAE 5W-30 Signature Series 100% Synthetic Motor Oil (ASLQT)
Drain Interval Information
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W30 Synthetic Motor Oil (OEFQT)
Above 0 F......10W-30
All TEMPS......5W-30
Automatic Transmission,A343F......AF3
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Standard Differential, Front......GL-5
Below 0 F......80W-90, 80W
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Limited Slip Differential, Front......GL-5*
All TEMPS......90
All TEMPS......90
Limited Slip Differential, Rear W/ Locking Diff......GL-5*
All TEMPS......90
Limited Slip Differential, Rear W/O Locking Diff......GL-5*
All TEMPS......90
Standard Differential, Rear W/O Locking Diff......GL-5
All TEMPS......90
Transfer Case,......GL-4
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Transfer Case,......GL-5
Fluids
Power Steering Fluid......AF3
Torque-Drive Synthetic Transmission Fluid (ATD1G) [1]
Clutch Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [2]
Brake Fluid......HB
[1] DEXRON®-III Automatic Transmission Fluid
[2] Hydraulic Brake Fluid, DOT 3
Redline Synthetic of an appropriate spec in mine and works great, much quieter than when I got it.
I am using amsoil severe gear in my transfer case 75w90:bounce:
Mobil 1, 75W-90 here.
Steve
Pretty sure thats a manual gbox cruiser, not an Auto. He doesn't reference.
Nope not a manual, just used that exact write up to do mine about 6 months ago. I could be wrong but I dont think a maual gb 100 series exists in the U.S., unless maybe it was imported.
