Hey all! I did some MUD searching but couldn't find anything. Please point me to the right post/s if I missed something.
This occurs after the 470 sits for a period of maybe 20 min or more...the kicker is that doesn't do it all the time after sitting. Maybe 50% of the time.
-When I start it after sitting for awhile it does not fire right away. It turns over maybe three times longer than usual and then fires. It does tend to stutter just a bit before firing as well (but not every time)
-I can let it run for a couple seconds, shut it off and then start it again and it starts right away. I cannot duplicate this prolonged start condition when the engine has been recently run.
This issue presents itself when ambient air temps are hot and cold.
Things I have done recently:
*Replaced the Battery
*Replaced the fuel Filter with Toyota filter
*Checked 20 Amp EFI fuse (looked good) I replaced it with a new one just in case.
I have an appointment with my mechanic coming up in a couple weeks. He said the fuel system has a check valve that may need replacing. Does anyone know of this check valve? I have had no luck finding out if this vehicle has this check valve. I thought maybe it could be something I could do myself and let my mechanic handle the other larger items we have planned. Thanks for any help! CHEERS!
