- Thread starter
- #21
Never did a compression test but drove it for another week and the heater stopped working which was enough for me to confirm HG failure along with the initial shop diagnosis.
Moved on to a 200 series. Enjoying the extra power but for me it leaves a lot to be desired vs the 100 series. I’ll likely go back at some point.
Here are a few cons of 200 series so far for anyone else considering the switch (some personal preference):
+ larger rims means less sidewall for stock tire replacement without spacers or some other modification
+ Center diff issues with not engaging or just intermittently flashing. It’s a known issue with no tested fix without replacement
+ I’m at 120k miles and it needed a new rear main seal and new struts among other items which is $$$$
+ lots of known coolant leak issues which doesn’t give me the same confidence in longevity that the 100 series did
+ reported issues with 4hi/low electric switch vs the 100 series manual stick
+ seats for me aren’t quite as comfortable and no armrest
+ cup holders are awful
+ not a fan of the electric opening rear tailgate. Just another expensive failure point in the future
The only pro personally so far is the extra power when towing.
