- Thread starter
- #21
Okay so the weather got warmer and I decided it was time to do some investigation. So I did the following:
1. first checked all the fuses with a tester reseated them, no luck
2. Took my drivers side door panel off to make sure all connectors are connected, no luck , all connectors were good.
3. I unplugged the orange wiring harnesses and looked at them and reconnected them back, no luck.
4. I tried to pull back the rubber grommet but it was darn near impossible. The space was so tight between the door and the car body that I couldn't pull it back enough to get a good look at the wires. Is there a certain way I should pull back on the rubber sleeve ?
What a disappointing feeling that I couldn't fix it.
. I really hope it's not the junction box as the stealership is saying it is.
Thanks anyway everyone for your kind support!
