Hey Guys, just had a dreaded Ignition column shaft broken which I had the Indy tech replace the whole unit (sample pict attached)
Car had the dis-connected neg terminal of the battery for 4-5 days.
Replacement went fine, no un usual lights on, it drives fine but it seems like A/C is not working now.
1)- With A/C off: If i turn the temp to lowest setting (cold), I still get the hot air.
2)- With A/C on: At the lowest setting (cold), I do get some cold air but as soon as I turn the temp to say 63*, once again it blows hot air
3)- It seems like, I can also hear a slight whistling sound as well coming from the vents?
Does this sound like a fuse issue or may be the blender(?) motor?
Please advice/help.
Thanks
Please advice/help.
Thanks
