Hi all,
I'm doing some wiring on my FJ62.
Two questions- Where have you located your ODB2 port (inside the cab)? I can't really find a good place to put it.
Second question- I'm wiring in an LED MIL light. It's a two wire light. From what I have read, the wire from the ECU is a ground that makes the light circuit when the constant power is connected to the ECU ground. So, I am assuming that I tap into the ground to the ODB2 port, run it to the light, and connect the constant positive, I should have a functioning light. Does this sound familiar?
2004 L59
2004 L59
