LS Intake Question (This is FJ62-related)
Durham, NC
I'm in the middle of swapping an LS into my FJ62. The donor engine is an LM7 from a 2006 Yukon. There's some differences with this engine (e.g,. return-less fuel rail, hydroboost PS pump, different bolt pattern for the oil pan, etc.)
My question is about the vacuum ports, though. I know there's one at the back of the engine for the brake booster. BUT, there's another about midway on the passenger side of the intake. Traditionally, you can break off a plastic tab and voila - you have a vacuum port nipple. With my engine, though, there's no plastic nipple - just a steel block off plug. I need to know the size of that plug so I can buy a fitting. This will power my xfer case vacuum system. 1/4 in is too small; 3/8 seems too big.
Any guesses on size?
Update - I'm an idiot. Disregard.
Got a pic? I won't be much help since I have geniii, but seems like ICTBillet sells a bunch of those types of parts. Might be worth giving them a ring if no one here knows.
i like to use a tee off the brake booster hose.
Disregard. I'm an idiot.
Hole was 1/4 NPT –– I mistook a 1/8 NPT plug for a 1/4 NPT, which is why I thought 1/4 was too small.
