Did you solve the vib problem??
I’m right there with you. I can actually play with the noise a bit by just feathering the throttle when coasting above 40mph or so. It’s that slight pressing/releasing of the throttle at speed that causes the noise (might I add that it’s not overly loud, but I can hear it. I don’t think my wife would notice).Bump
Evening Mud
Anyone resolve this? I'm getting a rumble grumble when decelerating especially between throttle on and that tiny spot between throttle off.
It also does it decelerating especially between 65-45mph.
All fluid new
New rear driveshaft solved different vibes
New 4:88 gears
New ARB lockers
New diff koyo bearing pro installed
New 100% Axle rebuild
Matching newer tires
New Mr front ujoints
Bla bla the list goes on
I should note she was doing this vibration before I did the axle, diff and gear/locker work.
I did think I noticed it less with the magic Mercedes silver slip yolk grease.
S@$& all that's left is a new front driveshaft and transfer case rebuildmaybe I'll plan to replace and rebuild.
I'll pull the front driveshaft, lock the CDL and drive it but this won't isolate if it's the front drive shaft or the output bearing on the front drive shaft to the transfer case.
Any other ideas Mud?
That's exactly it, great throttle discrimination.I’m right there with you. I can actually play with the noise a bit by just feathering the throttle when coasting above 40mph or so. It’s that slight pressing/releasing of the throttle at speed that causes the noise (might I add that it’s not overly loud, but I can hear it. I don’t think my wife would notice).
I wish I had an answer for you…
Speaking for myself, I don’t feel any play in the driveshaft, I did recently grease the u-joints, however a shop did grease the slips and I noticed the sound shortly after. They may have overdressed despite my suggestion of just two pumps.I should probably remove the zerk and just start afresh with the amount of grease.Maybe I missed it, but skimming through the thread, I didn't quite see the usual first-line suspects being addressed - dry front drive shaft u-joints, and too much grease in the slip yokes (essentially hydro-locking the drive shaft against compression).
3 inch lift? I did not see that mentioned in your opening post, its always good to throw out as much info as possible when describing a problem, anything over 2" seems to bring up drivetrain issues..
Regards
Dave
