My wife's '99 had the passenger side low-beam out so went and got new bulbs for both. Still didn't work.
Removed the passenger replacement bulb, checked connections which looked new, and then tested the voltage. 11.68 volts.
Tested the bulb off of the battery terminals and it worked. Tested voltage on drivers side and it was 11.88 volts.
Made a temporary secondary connection between the bulb and OEM connector to monitor the voltage. It was the same 11.68 volts until I plugged the bulb in and it then dropped to 0 which shows why it's not coming on.
Could this be the cause of the relay? I don't understand how the driver's side can come on but not the passenger. Aren't they connected in parallel?
