SOLD Loudoun county, Virginia, 1999 Toyota Landcruiser $5,000
Year
1999
  1. 100 Series
I am finially parting with my dear beloved landcruiser of 18 years. LC has 304600 miles and has been babied for its life that I owned it. Normal wear for a LC this old but strong as an ox. I have used amsoil in transmission, differentials, transfercase, and engine from the day I took ownership at 69K miles. Items replaced since i took ownership - Radiator and hoses, starter, coil packs upper and lower control arms and the rod ends (Moog problem solver products), tires (Michelin defenders) still have 85-90% life on them, water pump, timing belt, idler pulleys, serpentine belt, fan clutch, alternator, battery, one fuel injector, muffler, brakes (bosch). All was done within its life span that I have owned it. Most items are recent.
I am asking midrange kbb $5000. Landcruiser has corrosion in normal places (behind front wheels and behind right rear wheel). Frame is rock solid. Frame mounted trailer hitch.
Update - forgot to mention all new iridium spark plugs and new parking brake cable installed 4 years ago.
Can u post some undercarriage/engine bay pics? Also, where the rust is would be appreciated. Thank you!
Will do once I get a chance. It may take a few days.
No problem. I’m not in a rush.
Lots of work needed on this one, how does the undercarriage look?
I'm also in Loudoun county, would love to come and see it?
Under carriage is in good shape. Typical surface corrosion, but nothing too significant. There is one cross member over the rear axle that needs a welded repaired but overall good shape. Pm me if you want to take a look this week.
System will only let me attach 5 at a time.
